Disables Bluetooth capability on a switch.
| switch | Designates disabling switch capabilities. |
| bluetooth | Designates disabling Bluetooth capabilities on a switch. |
| discovery | Disables discoverable mode of the switch. Default is enabled. |
| pairing | Disables pairing ability with other Bluetooth-capable devices. Default is enabled. |
By default, discovery and pairing modes are enabled.
Using the command with no options disables Bluetooth capability on the switch. The discovery and pairing options disable discoverable mode and pairing ability, respectively.
To enable Bluetooth capabilities, use the enable switch bluetooth {discovery | pairing } command.
To view Bluetooth and discovery/pairing status, use the show switch bluetooth [statistics | inventory] command.
The following example disables Bluetooth capability on a switch:
# disable switch bluetooth
The following example disables discovery mode on a switch:
# disable switch bluetooth discovery
This command was first available in ExtremeXOS 30.3.
